Fluke 9010A signatures - now you can add them to Synalyze It! Pro (MAC)
If you run MAC OSX and you use Synalyze It! Pro (and why not if you aren't?) then Andreas has created a script that will allow you to see the Fluke 9010A Signature on any file you load! He said I can share it so it is attached to this email and I'll post it on the TTL FTP list shortly. Here are the instructions: -------------(quote with edits)---------------- The attached script does the trick. It uses the Python version of the slightly modified C version of the signature generation on GitHub repo. (translated by ChatGPT). If you bought Synalyze It! Pro via Mac App Store, the script should be placed here: "~/Library/Containers/com.synalyze-it.SynalyzeItPro/Data/Library/Application Support/Synalyze It! Pro/Scripts/GenerateFlukeSignature.script" or "~/Library/Application Support/Synalize It! Pro/Scripts" If you bought the downloaded version, cut out the “~/Library/Containers/com.synalyze-it.SynalyzeItPro/Data/Library" Alternatively you could also copy the script from the .script XML file and create a new script of type File in the script editor. When having the hex editor with the file in the foreground the script should appear in the Script menu. Then the log view can be opened at the bottom of the window pulling up, (there’s a split view handle) where the Fluke Signature now shows. -------------(end quote)---------- It works just fine! John :-#)# -- John's Jukes Ltd. 7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3 Call (604)872-5757 (Pinballs, Jukes, Video Games) flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Nice to see the fluke sig in PyThon ! I wish someone would figure out the 9100 signature.. ( yes, i know there is a crc32 script you can run ) William Stillwell Volunteer for The Phoenix - a 501c3 Organization - Providing outreach and events for those who are living a sober lifestyle. Member of MakerFX & Tampa Hackerspace both 501c3 organization - Providing Makers services in Tampa & Orlando Former Board member of the following fine organizations! Former Board Member & Co-Founder - Byte Amusement Group // Free Play Florida Arcade & Pinball Show a 501c3 organization Former Board Member - West Central Florida Group - a 501c3 Organization. - Providing Emergency Communications across Central Florida. Former Board Member - Inspiration labs, Inc. a 501c3 organization - Tampa's Premier Maker Space. On Wed, Mar 15, 2023 at 3:13 PM John Robertson via Techtoolslist < techtoolslist@flippers.com> wrote:
It works just fine!
John Robertson via Techtoolslist -
