MISSILE COMMAND fluke 9010a error on fide 4.1.9
I am trying to use the quarter arcade page to generate this script I copy and paste it into fide right off the generator page on quarter arcade And I keep getting errors when I go to send it to 9010a Any help on what I am doing wrong And how to set up these scripts to run would be great I also posted what I used Why am I getting the warning of file already exists , It looks like it is saving it in 2 spots I did hit the compile button to see if it would fix it Same error Thanks tony Here is what I get Starting process... WARNING: Include file already exists. File may have been included multiple times, or two files with the exact same file name may exist. It is recommended that you give your files distictive file names. C:\Program Files\Fluke FIDE\Scripts\Atari\mis\miss.9lc -> C:\Program Files\Fluke FIDE\Internal\miss.9lc (exists). 9010A Language Compiler - Version 1.2 Copyright(c) 1983 John Fluke Mfg. Co., Inc. line 177: program 03582002 >>Illegal program number Processing completed. SYSTEM ERROR: 380: Invalid property value ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !! ! ! Fluke 9010A Code Generator ! Process copyright QuarterArcade.com, LLC ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SETUP CODE !! Purpose: To set the pod include file and the pod being used, as well as !! relevant setup conditions. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! setup include "6502.pod" POD 6502 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: Main !! PURPOSE: Start the process. Introduce the program to refresh the !! operator's memory, and enter into the main menu. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program Main declarations !! Intro execute QuarterArcadeLogo !! Short delay to introduce program dpy MISSILE COMMAND - MISSILE aux MISSILE COMMAND - MISSILE REG8 = 10 execute DelayTics8 execute MainMenu !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: MainMenu !! PURPOSE: Give the user options to select from in menu format. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program MainMenu declarations assign REGB to Input MenuLp: Input = 0 aux _ aux _ aux MAIN MENU aux ____1=ROMMenu aux _ aux _ aux MENU COMMAND> dpy CMD> 1 execute GetKey if Input = 1 goto Menu1 !! hooks to ROMMenu goto MenuLp Menu1: !! ROMMenu execute ROMMenu dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp MenuF: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: ROMMenu !! PURPOSE: Give the user options to select from in menu format. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program ROMMenu declarations assign REGB to Input MenuLp: Input = 0 aux _ aux _ aux ROM MENU aux ____1=3582002 aux ____2=03582102 aux ____3=03582202 aux ____4=03582302 aux ____5=03582402 aux ____6=03582502 aux ____E=TEST ALL aux _ aux ____F=RETURN aux _ aux MENU COMMAND> dpy CMD> 1-6,E=ALL,F=UP execute GetKey if Input = 1 goto Menu1 !! hooks to 03582002 if Input = 2 goto Menu2 !! hooks to 03582102 if Input = 3 goto Menu3 !! hooks to 03582202 if Input = 4 goto Menu4 !! hooks to 03582302 if Input = 5 goto Menu5 !! hooks to 03582402 if Input = 6 goto Menu6 !! hooks to 03582502 if Input = E goto MenuE !! hooks to all tests goto MenuLp Menu1: !! 03582002 execute 03582002 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu2: !! 03582102 execute 03582102 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu3: !! 03582202 execute 03582202 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu4: !! 03582302 execute 03582302 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu5: !! 03582402 execute 03582402 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu6: !! 03582502 execute 03582502 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp MenuE: !! All tests execute 03582002 execute 03582102 execute 03582202 execute 03582302 execute 03582402 execute 03582502 dpy # dpy TESTS DONE aux TESTS DONE execute GetKey goto MenuLp MenuF: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582002 !! Purpose: Tests one ROM. $5000-$57FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582002 dpy ROM test @ 5000-57FF sig F25A aux ROM test @ 5000-57FF sig F25A ROM test @ 5000-57FF sig F25A !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582102 !! Purpose: Tests one ROM. $5800-$5FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582102 dpy ROM test @ 5800-5FFF sig 3977 aux ROM test @ 5800-5FFF sig 3977 ROM test @ 5800-5FFF sig 3977 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582202 !! Purpose: Tests one ROM. $6000-$67FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582202 dpy ROM test @ 6000-67FF sig E850 aux ROM test @ 6000-67FF sig E850 ROM test @ 6000-67FF sig E850 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582302 !! Purpose: Tests one ROM. $6800-$6FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582302 dpy ROM test @ 6800-6FFF sig EF62 aux ROM test @ 6800-6FFF sig EF62 ROM test @ 6800-6FFF sig EF62 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582402 !! Purpose: Tests one ROM. $7000-$77FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582402 dpy ROM test @ 7000-77FF sig B25D aux ROM test @ 7000-77FF sig B25D ROM test @ 7000-77FF sig B25D !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582502 !! Purpose: Tests one ROM. $7800-$7FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582502 dpy ROM test @ 7800-7FFF sig B888 aux ROM test @ 7800-7FFF sig B888 ROM test @ 7800-7FFF sig B888 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: KeyEnable !! Purpose: Wait for a key to be pressed !! Inputs: none !! Output: Reg B = 40; toggles the enabling of asynchronous keyboard interrupt !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program KeyEnable REGB = 40 !Initialize reg B dpy-+%B !Enable key interrupt to reg B !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: GetKey !! Purpose: Wait here until a key is pressed !! Inputs: none !! Calls to: KeyEnable !! Outputs: Register B = the value of a key pressed (0-3F) !! Based on program found in the GFI example from Fluke's documentation !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program GetKey execute KeyEnable ! Enable interrupt 1: LABEL 1 if REGB = 40 goto 1 ! Loop till key pressed (<40) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: DelayTics8 !! Purpose: Delays the number of tics specified by REG8 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program DelayTics8 REG1 = REG8 dloop: dec REG1 if REG1 > 0 goto dloop !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: QuarterArcadeLogo !! Purpose: I'm a geek. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program QuarterArcadeLogo dpy TECH.QUARTERARCADE.COM aux TECH.QUARTERARCADE.COM REG8 = 10 execute DelayTics8 _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Ok I fixed it The short name was all numbers was pre filled in on website Now it runs I am getting a error at 3000 The screen has garbage in back of the cities is what I am trying to fix I am having a problem seeing the looping On the board to find ware address 3000 is Any help would be great Thanks tony -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of tonyhtbsusa Sent: Sunday, October 20, 2013 12:05 AM To: Techtoolslist@flippers.com Subject: [Techtoolslist] MISSILE COMMAND fluke 9010a error on fide 4.1.9 I am trying to use the quarter arcade page to generate this script I copy and paste it into fide right off the generator page on quarter arcade And I keep getting errors when I go to send it to 9010a Any help on what I am doing wrong And how to set up these scripts to run would be great I also posted what I used Why am I getting the warning of file already exists , It looks like it is saving it in 2 spots I did hit the compile button to see if it would fix it Same error Thanks tony Here is what I get Starting process... WARNING: Include file already exists. File may have been included multiple times, or two files with the exact same file name may exist. It is recommended that you give your files distictive file names. C:\Program Files\Fluke FIDE\Scripts\Atari\mis\miss.9lc -> C:\Program Files\Fluke FIDE\Internal\miss.9lc (exists). 9010A Language Compiler - Version 1.2 Copyright(c) 1983 John Fluke Mfg. Co., Inc. line 177: program 03582002 >>Illegal program number Processing completed. SYSTEM ERROR: 380: Invalid property value ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !! ! ! Fluke 9010A Code Generator ! Process copyright QuarterArcade.com, LLC ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SETUP CODE !! Purpose: To set the pod include file and the pod being used, as well as !! relevant setup conditions. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! setup include "6502.pod" POD 6502 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: Main !! PURPOSE: Start the process. Introduce the program to refresh the !! operator's memory, and enter into the main menu. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program Main declarations !! Intro execute QuarterArcadeLogo !! Short delay to introduce program dpy MISSILE COMMAND - MISSILE aux MISSILE COMMAND - MISSILE REG8 = 10 execute DelayTics8 execute MainMenu !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: MainMenu !! PURPOSE: Give the user options to select from in menu format. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program MainMenu declarations assign REGB to Input MenuLp: Input = 0 aux _ aux _ aux MAIN MENU aux ____1=ROMMenu aux _ aux _ aux MENU COMMAND> dpy CMD> 1 execute GetKey if Input = 1 goto Menu1 !! hooks to ROMMenu goto MenuLp Menu1: !! ROMMenu execute ROMMenu dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp MenuF: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! SUB: ROMMenu !! PURPOSE: Give the user options to select from in menu format. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program ROMMenu declarations assign REGB to Input MenuLp: Input = 0 aux _ aux _ aux ROM MENU aux ____1=3582002 aux ____2=03582102 aux ____3=03582202 aux ____4=03582302 aux ____5=03582402 aux ____6=03582502 aux ____E=TEST ALL aux _ aux ____F=RETURN aux _ aux MENU COMMAND> dpy CMD> 1-6,E=ALL,F=UP execute GetKey if Input = 1 goto Menu1 !! hooks to 03582002 if Input = 2 goto Menu2 !! hooks to 03582102 if Input = 3 goto Menu3 !! hooks to 03582202 if Input = 4 goto Menu4 !! hooks to 03582302 if Input = 5 goto Menu5 !! hooks to 03582402 if Input = 6 goto Menu6 !! hooks to 03582502 if Input = E goto MenuE !! hooks to all tests goto MenuLp Menu1: !! 03582002 execute 03582002 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu2: !! 03582102 execute 03582102 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu3: !! 03582202 execute 03582202 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu4: !! 03582302 execute 03582302 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu5: !! 03582402 execute 03582402 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp Menu6: !! 03582502 execute 03582502 dpy # dpy TEST DONE aux TEST DONE execute GetKey goto MenuLp MenuE: !! All tests execute 03582002 execute 03582102 execute 03582202 execute 03582302 execute 03582402 execute 03582502 dpy # dpy TESTS DONE aux TESTS DONE execute GetKey goto MenuLp MenuF: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582002 !! Purpose: Tests one ROM. $5000-$57FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582002 dpy ROM test @ 5000-57FF sig F25A aux ROM test @ 5000-57FF sig F25A ROM test @ 5000-57FF sig F25A !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582102 !! Purpose: Tests one ROM. $5800-$5FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582102 dpy ROM test @ 5800-5FFF sig 3977 aux ROM test @ 5800-5FFF sig 3977 ROM test @ 5800-5FFF sig 3977 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582202 !! Purpose: Tests one ROM. $6000-$67FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582202 dpy ROM test @ 6000-67FF sig E850 aux ROM test @ 6000-67FF sig E850 ROM test @ 6000-67FF sig E850 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582302 !! Purpose: Tests one ROM. $6800-$6FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582302 dpy ROM test @ 6800-6FFF sig EF62 aux ROM test @ 6800-6FFF sig EF62 ROM test @ 6800-6FFF sig EF62 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582402 !! Purpose: Tests one ROM. $7000-$77FF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582402 dpy ROM test @ 7000-77FF sig B25D aux ROM test @ 7000-77FF sig B25D ROM test @ 7000-77FF sig B25D !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: 03582502 !! Purpose: Tests one ROM. $7800-$7FFF !! Generated ROM test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program 03582502 dpy ROM test @ 7800-7FFF sig B888 aux ROM test @ 7800-7FFF sig B888 ROM test @ 7800-7FFF sig B888 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: KeyEnable !! Purpose: Wait for a key to be pressed !! Inputs: none !! Output: Reg B = 40; toggles the enabling of asynchronous keyboard interrupt !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program KeyEnable REGB = 40 !Initialize reg B dpy-+%B !Enable key interrupt to reg B !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: GetKey !! Purpose: Wait here until a key is pressed !! Inputs: none !! Calls to: KeyEnable !! Outputs: Register B = the value of a key pressed (0-3F) !! Based on program found in the GFI example from Fluke's documentation !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program GetKey execute KeyEnable ! Enable interrupt 1: LABEL 1 if REGB = 40 goto 1 ! Loop till key pressed (<40) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: DelayTics8 !! Purpose: Delays the number of tics specified by REG8 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program DelayTics8 REG1 = REG8 dloop: dec REG1 if REG1 > 0 goto dloop !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! !! Program: QuarterArcadeLogo !! Purpose: I'm a geek. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! program QuarterArcadeLogo dpy TECH.QUARTERARCADE.COM aux TECH.QUARTERARCADE.COM REG8 = 10 execute DelayTics8 _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
check out the missile command bit of my repair log, I had something similar once before, it may help http://www.arcades.plus.com/repair.htm
On 21 October 2013 at 13:27 tonyhtbsusa <tony@htbsusa.com> wrote: The screen has garbage in back of the cities is what I am trying to fix
mike@the-coates.com -
tonyhtbsusa
