Hi. I'm not expecting anyone will know the answer to this (I get the feeling few own a 9100 and fewer make much use of it) but I'll ask regardless, hope springs eternal. Does anyone know of a use case where the 9100 system software requires that the disk change feature functions correctly? What's the "disk change feature" you might ask? There is a test for it in section 4-75 of the 9100FT service manual. Basically when the disk is changed an interrupt is raised through DTIO#2. The test in the manual is basically that subsequent iterations of the same operation should not access the disk unless the disk has been changed between iterations. However I'm not aware of any part of the software that relies on this feature working. When loading the system sw from multiple floppies, there is a manual keystroke required to flag a disk change. It's interesting how this is implemented on 9100. For drive 1 it;s handled on pin 14 of the floppy cable, which per the Shugart standard is normally DS2. For drive 2 it's handled on pin 4 on the 9100A and pin 2 on the 9100FT (though it's jumperable back to 4). The line is held low whenever a disk is inserted and held high whenever ejected. The Shugart 34 pin standard has diskchange on pin 2 but the semantics of it's signal are totally different, it only changes after a stepping. It's also interesting that the disk change test doesn't work correctly when the firmware is configured for a Sony floppy. It does when configured as a Canon floppy. I suspect this is why Jon (Porchy) needed to ground pin 14 to get his HxC USB floppy emulator to work. Thanks Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Tony Jones writes:
Hi.
Other systems I’ve worked on will cache the disk directory when you read a floppy, then use the disk change line to know if the cache should be flushed. The 9100 might be similar, maybe try tying the line low and reading two userdisks in succession. -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
On Fri, Nov 16, 2018, 10:54 AM Ian Eure <ian@retrospec.tv wrote:
Question again. Does anyone know of a use case where the 9100 system software requires that the disk change feature functions correctly? _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
