6502 NOP, or Clock divider
I'm looking for some schematics to build a 6502 NOP that will produce catbox sigs when used with the HP5004a. I think someone mentioned they built one with 2 ls393's I assume that would be the easiest way, instead of building a clock divider to use for my clock signal. If someone could point me in the right direction.. Thanks, Kevin _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Kevin __________
A NOP can easily be built by using a 6502 CPU and bending the data lines up over the top, then hardwire them to NOP and disable any watchdog reset, then plug the modified CPU into the board and power it up! I have a picture up on TTL FTP of several modified CPUs and an Eprom (can't remember using that - might work), also a PDF of an article written back in the 70s about making your own...both of these are files starting with "NOP". John :-#)# _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
That won't give catbox signatures on the 5004 though. It was me that posted about it I think. When I built mine I just used the schematics for the catbox. I'm sure Andy Welburn built one as well and I think he made his slightly differently? Maybe he wrote up some schems?
I just went ahead and built a clock divider out of 1 74s74 connecting the clock from a normal 6502 nop, into pin 3, then feeding not q pin 6 into d pin 2. and using q pin 5 as my new clock. It get's atari sigs now, and if I need to just use normal 5004a sigs, I can just pull the clock divider. Kevin On Thu, Jun 17, 2010 at 3:36 AM, Martin White <martin@guddler.co.uk> wrote:
Awesome. Make me one please! Now I can sell my cat box. -- Sent from my Palm Pre On Jun 17, 2010 5:37 AM, Kevin Moore <talon.k@gmail.com> wrote: I just went ahead and built a clock divider out of 1 74s74 connecting the clock from a normal 6502 nop, into pin 3, then feeding not q pin 6 into d pin 2. and using q pin 5 as my new clock. It get's atari sigs now, and if I need to just use normal 5004a sigs, I can just pull the clock divider. Kevin On Thu, Jun 17, 2010 at 3:36 AM, Martin White <martin@guddler.co.uk> wrote: > > > A NOP can easily be built by using a 6502 CPU and bending the data lines > up over the top, then hardwire them to NOP and disable any watchdog reset, > then plug the modified CPU into the board and power it up! > > That won't give catbox signatures on the 5004 though. > > It was me that posted about it I think. When I built mine I just used the > schematics for the catbox. I'm sure Andy Welburn built one as well and I > think he made his slightly differently? Maybe he wrote up some schems? > > > I have a picture up on TTL FTP of several modified CPUs and an Eprom > (can't remember using that - might work), also a PDF of an article written > back in the 70s about making your own...both of these are files starting > with "NOP". > > > > John :-#)# > > _______________________________________________ > Techtoolslist mailing list > Techtoolslist@flippers.com > http://seven.pairlist.net/mailman/listinfo/techtoolslist > FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment > Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ > _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Oh wait, which wire went where? I'll see about bread boarding up a couple, with some switches so you can go from Atari Sigs, to Standard NOP sigs. Although, what other games besides atari used 6502 processors? It just makes sense to have the clock divider because all the atari stuff have cat box sigs. Kevin On Thu, Jun 17, 2010 at 10:13 AM, Pat Danis <patdanis@verizon.net> wrote:
-- Sent from my Palm Pre On Jun 17, 2010 5:37 AM, Kevin Moore <talon.k@gmail.com<lt%3Btalon.k@gmail.com>> wrote:
Kevin
On Thu, Jun 17, 2010 at 3:36 AM, Martin White <martin@guddler.co.uk<lt%3Bmartin@guddler.co.uk>> wrote:
> with "NOP".
> > John :-#)#
All Gottlieb System 80 / A / B pinball machines had the 6502 processor at the heart of their CPU boards. Stuart
Date: Thu, 17 Jun 2010 11:43:36 -0500 From: talon.k@gmail.com To: patdanis@verizon.net; techtoolslist@flippers.com Subject: Re: [Techtoolslist] 6502 NOP, or Clock divider
Kevin
Kevin
> with "NOP".
> > John :-#)#
_________________________________________________________________ Look 'em in the eye: FREE Messenger video chat http://go.microsoft.com/?linkid=9734386 _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Kevin Moore -
Pat Danis -
Stuart Banks
